Product
HP 302 Ink cartridge 1-Pack Dye-Based Black for Deskjet
Quicklinx: CNWFWS00 Mfr#: F6U66AE#BA3
Print high-quality documents with Original HP ink cartridges – designed with fraud protection and smart low-ink alerts to deliver worry-free performance and consistent results you can count on.
Get the most from your HP printer and your ink. Print all the high-quality photos and documents you need, using Original HP ink cartridges that help ensure your HP printer delivers the consistent results you expect.
Easily complete your projects. More accurate alerts can help ensure you don’t run out of ink at the wrong time.
Help ensure the best possible prints for home, school and work with cartridges built and tested with your HP printer and designed to deliver consistently outstanding prints.
Choose Original HP ink cartridges specially designed to work with your printer.
It’s simple to save time, money and hassle with Original HP cartridges that fit how you live, play and print. Count on consistent, top-quality results you expect from HP at home or on the go.
Print more for less with optional Original HP high-yield ink cartridges.
  • Choose innovative ink that makes it simple to get more
    Easily complete your projects. More accurate alerts can help ensure you don't run out of ink at the wrong time.
  • Rely on cartridges designed to deliver flawless results
  • Enjoy printing made easy
    Print more for less with Original HP high-yield ink cartridges.
HP 302 - black - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Black (pigmented)
3.5 ml
Yield
Up to 190 pages ISO/IEC 24711
Compatible with
Deskjet 1110, 1112, 2130, 2131, 2132, 2134, 2136, 3630, 3631, 3632, 3633, 3634, 3635, 3636, 3637, 3638; Envy 4512, 4516, 4520, 4521, 4522, 4523, 4524, 4525, 4526, 4527, 4528; Officejet 3830, 3831, 3832, 3833, 3834, 3835, 4650, 4652, 4654, 4655, 4656, 4657, 4658, 5220, 5230, 5232, 5255, 5258
Shipping Width
11.3 cm
Shipping Depth
3.7 cm
Shipping Height
11.5 cm
Shipping Weight
50 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Black (pigmented)
Included Qty
1-pack
3.5 ml
Yield
Compatible with
HP Deskjet 1110, 1112, 2130, 2131, 2132, 2134, 2136, 3630, 3631, 3632, 3633, 3634, 3635, 3636, 3637, 3638 , HP Envy 4512, 4516, 4520, 4521, 4522, 4523, 4524, 4525, 4526, 4527, 4528 , HP Officejet 3830, 3831, 3832, 3833, 3834, 3835, 4650, 4652, 4654, 4655, 4656, 4657, 4658, 5220, 5230, 5232, 5255, 5258
