HP 300XL Black Ink Cartridge prints laser-quality text documents and sharp images that resist fading. This original HP ink cartridge is designed to deliver user-friendly features, including technology that lets you finish printing a critical job even when you're low on a specific ink. Get great value when you choose a high-capacity cartridge designed for frequent printing.
HP 300 Ink Cartridges print laser-quality text documents and sharp images that resist fading. Easily choose the original HP ink cartridge tailored to fit your printing needs. HP offers ink cartridge options designed to give you the best value, whether you print in standard or higher volumes. This original HP ink cartridge is designed to deliver user-friendly features, including technology that lets you finish printing a critical job even when you're low on a specific ink.
Print laser-quality text and vivid colour images
Print laser-quality text and sharp graphics, using Original HP inks. -
Get affordable printing with easy-to-use cartridges
Get 3 times more black printed pages and a better value, using a high-capacity ink cartridge. -
Count on HP for a superior printing experience
HP is a leader in service and support, providing a warranty for reliability you can count on.
- HP 300XL - High Yield - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black
- Capacity
- 12 ml
- Cartridge Yield
- High Yield
- Cartridge Features
- HP Vivera
- Yield
- Up to 600 pages
- Compatible with
- Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
- Shipping Width
- 11.6 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.6 cm
- Shipping Weight
- 0.1 kg
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black
- Included Qty
- 1-pack
- Capacity
- 12 ml
- Cartridge Yield
- High Yield
- HP Vivera
- Yield
- Up to 600 pages
- Compatible with
- HP Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
