HP 300XL 2 Pack High Yield Tri Colour Original Ink Cartridge
Quicklinx: 9K0CWS00 Mfr#: D8J44AE
HP 300XL Tri-color Ink Cartridge 2-Pack lets you print vivid colour documents and finely-detailed images while getting great value. This high-capacity Original HP ink cartridge is designed to deliver user-friendly features and consistent.
  • Print vivid colour documents, reports and letters that resist fading with Original HP inks
    Print color images with enhanced detail. Dual drop weight technology-ink technology included in the cartridge-delivers an extremely small drop size for photos with smooth, even color and fine detail.Archive documents that maintain text and color quality for decades-without fading-using Original HP inks. Count on HP ink and paper to ensure stored legal documents, awards and photos maintain their image quality for years to come.
  • Enjoy user-friendly features at a great deal
    Finish a critical print job even when one cartridge runs low on ink-printing is completed with the remaining black or color cartridges. Just remove the consumed cartridge to finish printing the document. Color print jobs will be printed in grayscale.Get quick and easy cartridge loading. Cartridge technology ensures that you're loading the right color of ink into the right spot. It even helps you load optional cartridges properly.
  • Count on Original HP ink cartridges for consistent, reliable performance
    HP proprietary inks prevent corrosion and clogging of the printhead, ensuring the best prints.HP printers, inks and papers are designed and tested together for optimal results.
HP 300XL - 2-pack - High Yield - colour (cyan, magenta, yellow) - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Colour (cyan, magenta, yellow)
Cartridge Yield
High Yield
Yield
Up to 440 pages ISO/IEC 24711
Included Qty
2-pack
Compatible with
Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
2-pack
Cartridge Yield
High Yield
Yield
Compatible with
HP Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
