HP 300XL 2-pack Black Original Ink Cartridge print laser-quality text documents and images that resist fading. This two high capacity Original HP ink cartridges are designed to deliver user-friendly features and a great value.
Designed to work the first time, every time
Be assured that Original HP Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together
Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Crisp text and graphics
Print everyday documents that look great with crisp text and graphics, using Original HP inks. -
High-yield and 2-pack options available
Get 3 times more black printed pages and 2 times more colour printed pages, using optional high-yield ink cartridges. Print more pages and replace less often than standard Original HP ink cartridges. Or, buy convenient 2-packs.
- HP 300XL - 2-pack - High Yield - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black
- Cartridge Yield
- High Yield
- Yield
- Up to 600 pages ISO/IEC 24711
- Included Qty
- 2-pack
- Compatible with
- Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black
- Included Qty
- 2-pack
- Cartridge Yield
- High Yield
- Yield
- Compatible with
- HP Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
