HP 300 Black Original Ink Cartridge
Quicklinx: 558WWS00 Mfr#: CC640EE#UUS
Type: Ink Cartridge
Technology: Ink-Jet
£17.49 ex VAT
£20.98 inc VAT
HP 300 Black Ink Cartridges print laser-quality text documents and sharp images that resist fading. Enjoy an affordable price for everyday printing. This Original HP ink cartridge is designed to deliver user-friendly features, including technology that lets you finish printing a critical job even when you're low on a specific ink.
HP 300 Ink Cartridges print laser-quality text documents and sharp images that resist fading. Easily choose the Original HP ink cartridge tailored to fit your printing needs. HP offers ink cartridge options designed to give you the best value, whether you print in standard or higher volumes. This Original HP ink cartridge is designed to deliver user-friendly features, including technology that lets you finish printing a critical job even when you're low on a specific ink.
  • Print laser-quality text and vivid colour images
    Print high-quality documents with laser-quality text and vivid colour graphics, using Original HP inks.
  • Affordable printing with easy-to-use cartridges
    Get 3 times more black printed pages and 2 times more colour printed pages, using high-capacity cartridges.Know when to repurchase. Use the ink level gauge to monitor ink levels.
  • Take advantage of legendary HP reliability
    HP is a leader in service and support, providing a warranty for reliability you can count on.
HP 300 - black - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
4 ml
Cartridge Features
HP Vivera
Yield
Up to 200 pages
Compatible with
Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
Shipping Width
11.6 cm
Shipping Depth
11.5 cm
Shipping Height
3.6 cm
Shipping Weight
0.1 kg
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
1-pack
4 ml
Cartridge Features
HP Vivera
Yield
Up to 200 pages
Compatible with
HP Deskjet D2530, D2545, D2560, D2563, D2566, F4210, F4213, F4224, F4230, F4235, F4240, F4250, F4272, F4273, F4274, F4275, F4280, F4283, F4288, F4292, F4293
Type: Ink Cartridge
Technology: Ink-Jet
Brand: HP
Stock Status: While stocks last
Stock Status: Clearance
