HP 290 G1 SFF Intel Core i3-8100 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: F6WFWS00 Mfr#: 3ZE01EA#ABU
  • Core i3
Take on your everyday work at an affordable price with the HP 290 SFF. Get the computing power you need while minimizing the PC footprint and the total cost of ownership-now that's a smart investment.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Hassle-free connectivity
    Get fast and easy connections with optional Gigabit LAN and WLAN featuring 802.11ac protocol and Bluetooth 4.2 connectivity.
  • Peripheral support
    Support two independent displays with VGA and HDMI connectivity and plug in up to 8 compatible USB devices and utilize a serial port.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Clean software image
    With the clean, professional software image on the HP 290 SFF, you will be productive in no time!
HP 290 G1 - SFF - Core i3 8100 3.6 GHz - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Intel Core i3 (8th Gen) 8100 / 3.6 GHz (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 630
Audio Output
Stereo
GigE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
27 cm x 29.6 cm x 9.5 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express 1.1 x1
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1 , 2 (total) / 2 (free) x M.2 Card
2 x USB 3.1 Gen 1 (2 in front) , 4 x USB 2.0 (4 rear) , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x HDMI (1 rear) , 1 x VGA , 1 x microphone , 1 x serial , 2 x USB 3.1
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Power Provided
180 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
27 cm
29.6 cm
9.5 cm
4.2 kg
10 - 90% (non-condensing)
