Take on your everyday work at an affordable price with the HP 290. Get the computing power you need and the total cost of ownership - now that's a smart investment.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Port support
Make connections to peripherals with eight USB ports on the HP 290 G1 MT with two front USB 3.0 ports, two rear USB 3.0, and four rear USB 2.0 ports. Support two independent displays with VGA and HDMI connectivity. -
PC management made more manageable
Spend less time and get right to the updates you need with HP Support Assistant. -
Clean software image
With the clean, professional software image on the HP 290 G1 MT, you will be productive in no time!
- HP 290 G1 - micro tower - Core i3 7100 3.9 GHz - 4 GB - SSD 256 GB
- Personal computer - micro tower
- Localisation
- Processor
- Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Smart Cache
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 630
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Recovery Manager, HP Support Assistant, HP ePrint, Windows Defender, HP Velocity, HP JumpStart, HP JetAdvantage
- 17 cm x 27.4 cm x 33.8 cm
- 5.45 kg
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Ethernet Controller
- Realtek RTL8111G-CG
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 2.0 x1
- 4 x USB 2.0 , 1 x headphones/microphone (1 in front) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power supply
- Voltage Required
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 17 cm
- 27.4 cm
- 33.8 cm
- 5.45 kg
- 0 °C
- 40 °C
- 10 - 90%
