HP 285 G3 MT Ryzen 3 Pro 2200G 8GB 256GB SSD Windows 10 Pro
Quicklinx: DS34WS00 Mfr#: 3VA15EA#ABU
Optimize your resources with the HP 285 MT equipped with powerful processors, security features, and essential tools for business. This is an easy PC to set up with a scalable and functional design that can grow with your business.
  • Simply reliable
    The HP 285 MT delivers reliable performance for your business with the tools you need for work. Enhance your experience with the optional HP Conferencing Keyboard and HP Business Headset for collaboration.
  • Functional design
    Enjoy the full desktop experience on the scalable HP 285 MT with a functional design that compliments your workspace and is easy to set up and use.
  • Optimized performance
    Choose from 7th generation AMD PRO APUs or an optional AMD Ryzen 3, 5, or 7 PRO CPU to deliver powerful desktop performance optimized for dependable daily productivity with up to 32 GB of DDR4 memory.
  • Legacy support
    PCIe x1, PCIe x16 slots and legacy support of PCI slot, serial port, optional PS/2 and optional parallel ports on the HP 285 MT help ensure broad compatibility with existing technology investments.
HP 285 G3 - micro tower - Ryzen 3 2200G 3.5 GHz - 8 GB - SSD 256 GB - UK
Personal computer - micro tower
AMD Ryzen 3 2200G / 3.5 GHz (3.7 GHz) (Quad-Core)
Cache Memory
4 MB L3 Cache
Cache Per Processor
4 MB
RAM
8 GB DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - 3D V-NAND technology, triple-level cell (TLC), HP Value
Optical Storage
DVD-Writer
Graphics Controller
AMD Radeon Vega 8
Audio Output
Stereo
GigE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17 cm x 33.8 cm x 27.75 cm
5.4 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
L2 cache
2 MB
CPU Upgradability
Upgradable
Chipset Type
AMD B350
Cache Memory
Installed Size
L3 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon Vega 8
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111G-CG
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe x16 , 1 PCIe x1
6 x USB 3.1 Gen 1 (2 front, 4 rear) , 2 x USB 2.0 , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Power Provided
180 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
17 cm
33.8 cm
27.75 cm
5.4 kg
