HP 285 G2 MT 1 x A series A6-5400B 4GB 500GB HDD Windows 7 Professional (64-bit)
Quicklinx: C7WKWS00 Mfr#: T9T25EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
Optimize your resources with the HP 285 MT equipped with powerful processors, security features, and essential tools for business. This easy to set up PC has a scalable and functional design that can grow with your business.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Help secure critical data
    The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials.
  • Six USB ports
    Make connections to peripherals with six USB ports on the HP 285 MT. Two front USB 2.0 and two rear USB 2.0 ports are ready to connect to compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Valuable support at your service
    Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
HP 285 G2 - micro tower - A6 5400B 3.6 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower
AMD A6 5400B / 3.6 GHz (, up to 3.8 GHz, (Dual-Core)
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
AMD Radeon HD 7480D
Audio Output
Stereo
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
CyberLink Power2Go, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, HP BIOS Configuration Utility (free download)
17 cm x 35.5 cm x 35.88 cm
6.11 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A6 5400B
Clock Speed
3.6 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon HD 7480D
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Keyboard
Keyboard
USB
Localization & Layout
Ethernet Controller
Realtek RTL8111G
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x DIMM 240-pin
4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x PS/2 keyboard / mouse , 1 x serial
Theft/Intrusion Protection
UL, CCC, FCC, RoHS, WEEE, CECP, CEL, SEPA
Power supply
Power Provided
180 Watt
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
Sustainability Information
ENERGY STAR Certified
17 cm
35.5 cm
35.88 cm
6.11 kg
10 °C
35 °C
10 - 90% (non-condensing)
