Optimize your resources with the HP 285 MT equipped with a powerful processor, security features, and essential tools for business. This easy to set up PC has a scalable and functional design that can grow with your business.
Simply reliable
The HP 285 MT delivers reliable performance for your business with the tools you need for work. Enhance your experience with the optional HP Conferencing Keyboard and HP Business Headset for collaboration.
Optimized performance
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver powerful desktop performance optimized for dependable daily productivity and collaboration across your business.
Functional design
Enjoy the full desktop experience on the scalable HP 285 MT with a functional design that compliments your workspace and is easy to set up and use.
Legacy support
PCIe x1, PCIe x16 slots and legacy support of PCI slot, serial, and parallel ports along with VGA and Display Port 1.2 on the HP 285 Microtower helps ensure broad compatibility with existing technology investments.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Help secure critical data
The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials. -
Six USB ports
Make connections to peripherals with six USB ports on the HP 285 MT. Two front USB 2.0 and two rear USB 2.0 ports are ready to connect to compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone. -
PC management made more manageable
Spend less time and get right to the updates you need with HP Support Assistant. -
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
- HP 285 G2 - micro tower - A8 PRO-7600B 3.1 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - micro tower
- Localisation
- Processor
- AMD A8 PRO-7600B / 3.1 GHz (, up to 3.8 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- CyberLink Power2Go, Skype, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP BIOS Configuration Utility (free download)
- 17 cm x 35.5 cm x 35.88 cm
- 6.11 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A8 PRO-7600B
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD A78 FCH
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP USB Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111G-CG
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI
- 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones/microphone (1 in front) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
- Theft/Intrusion Protection
- UL, CCC, FCC, RoHS, WEEE, CECP, CEL, SEPA
- Power supply
- Power Provided
- 180 Watt
- Efficiency
- 85%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 17 cm
- 35.5 cm
- 35.88 cm
- 6.11 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
