HP 285 G2 - A series A8 PRO-7600B 3.1 GHz - 4 GB - 500 GB
Quicklinx: CH5LWS00 Mfr#: Z2J30EA#ABU
  • AMD Radeon R7
Optimize your resources with the HP 285 MT equipped with a powerful processor, security features, and essential tools for business. This easy to set up PC has a scalable and functional design that can grow with your business.
Simply reliable
The HP 285 MT delivers reliable performance for your business with the tools you need for work. Enhance your experience with the optional HP Conferencing Keyboard and HP Business Headset for collaboration.
Optimized performance
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver powerful desktop performance optimized for dependable daily productivity and collaboration across your business.
Functional design
Enjoy the full desktop experience on the scalable HP 285 MT with a functional design that compliments your workspace and is easy to set up and use.
Legacy support
PCIe x1, PCIe x16 slots and legacy support of PCI slot, serial, and parallel ports along with VGA and Display Port 1.2 on the HP 285 Microtower helps ensure broad compatibility with existing technology investments.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Help secure critical data
    The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials.
  • Six USB ports
    Make connections to peripherals with six USB ports on the HP 285 MT. Two front USB 2.0 and two rear USB 2.0 ports are ready to connect to compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Valuable support at your service
    Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
HP 285 G2 - micro tower - A8 PRO-7600B 3.1 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower
AMD A8 PRO-7600B / 3.1 GHz (, up to 3.8 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
CyberLink Power2Go, Skype, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP BIOS Configuration Utility (free download)
17 cm x 35.5 cm x 35.88 cm
6.11 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A8 PRO-7600B
Clock Speed
3.1 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
HP USB Mouse
USB
Ethernet Controller
Realtek RTL8111G-CG
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5"
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI
4 x USB 2.0 (2 front, 2 rear) , 1 x headphones/microphone (1 in front) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
Theft/Intrusion Protection
UL, CCC, FCC, RoHS, WEEE, CECP, CEL, SEPA
Power supply
Power Provided
180 Watt
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
17 cm
35.5 cm
35.88 cm
6.11 kg
10 °C
35 °C
10 - 90% (non-condensing)
