Take on your everyday work at an affordable price with the HP 280 SFF. Get the computing power you need while minimizing the PC footprint and the total cost of ownership-now that's a smart investment.
Performance
New Intel and Microsoft technology: Intel H110 Chipset with 6th generation processors and IntelĀ® HD Graphics 530 or 510 (varies by processor).
Up to 32GB DDR4 memory (2 slots)
128 GB SSD drives.
Provides fast boot time with the high performing storage option from HP
Keep Up with the Work Space
Offers VGA and HDMI port, Giga-bit LAN, 8 USB ports (including 2 USB 3.0 in front), integrated SD card reader, and optional Intel wireless LAN
Front combo audio jack works perfectly with your cellphone headset without a converter cable
7.8L chassis that works well in both horizontal and vertical orientation
Device Security and Manageability
Management utility "HP Touchpoint Manager" by HP, developed for small and medium business
Enhanced Collaboration
HP Conferencing Keyboard and headset for enhanced video conferencing
Latest Technology
Refresh with IntelĀ® 6th Gen processors and H110 chipset.
Microsoft Windows 10
Performance Boost
With DDR4 memory and optional SSD up to 128GB
Keep Up With Your Need
Up to 8 USB ports (including 2 USB 3.0 in front) and embedded SD reader for your media card. HDMI port gives you compatibility with the monitors Combo audio jack works well with your headset worry-free.
Easy to Deploy
Reliable thermal with no vents on the side or top, for your easy deployment together with a monitor
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Eight USB ports
Connect peripherals and devices via an HDMI port, a VGA port, two front USB, and six rear USB ports. -
PC management made more manageable
Spend less time and get right to the updates you need with HP Support Assistant. -
Clean software image
Accidents happen. HP can help
Optional HP Care Packs with Accidental Damage Protection helps you avoid out-of-pocket repair or replacement costs and delivers service right to your door.
- HP 280 G2 - SFF - Pentium G4400 3.3 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Pentium G4400 / 3.3 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 3 in 1
- Graphics Controller
- Intel HD Graphics 510
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- CyberLink Power2Go, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink Power Media Player
- 29 cm x 27 cm x 10 cm
- 3.66 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site , Technical support - phone consulting - 1 year
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
- Slots
- 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
- 2 x USB 3.0 (2 in front) , 6 x USB 2.0 , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, FCC, RoHS, WEEE, CECP, CEL, SEPA
- Power supply
- Power Provided
- 180 Watt
- Efficiency
- 85%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 29 cm
- 27 cm
- 10 cm
- 3.66 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
