Take on your work with the HP 280 MT desktop PC. Get the computing power you need for your business while minimizing the total cost of ownership-now that's a smart investment.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Help secure critical data
The embedded Trusted Platform Module 1.2 (TPM) is field upgradeable to TPM 2.0 through a firmware upgrade which provides hardware-based encryption keys to help secure your data, e-mail, and user credentials. -
Eight USB ports
Make connections to peripherals with eight USB ports on the HP 280 MT. Two front and four rear USB 2.0 ports are ready to connect to USB compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone. -
PC management made more manageable
Quickly get to the updates you need with HP Support Assistant. -
Simple wireless printing
Make better use of your workspace. HP ePrint makes wireless printing simple, no need for drivers. -
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
- HP 280 G2 - micro tower - Pentium G4400 3.3 GHz - 4 GB - HDD 500 GB
- Personal computer - micro tower
- Localisation
- Processor
- Intel Pentium G4400 / 3.3 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 510 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP BIOS Configuration Utility (free download)
- 17 cm x 35.5 cm x 35.88 cm
- 6.11 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DVI
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111G-CG
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
- 6 x USB 2.0 (2 front, 4 rear) , 1 x headphones/microphone (1 in front) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x DVI-D
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, FCC, WEEE, CECP, CEL, SEPA
- Power supply
- Voltage Required
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 17 cm
- 35.5 cm
- 35.88 cm
- 6.11 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
