The fully functional HP 260 Desktop Mini PC delivers the benefit of space saving design that can grow with your business and is equipped with the essential tools you need at an affordable price.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Power-saving processors
Do your part to reduce energy use and costs with processors that help consume less than half the energy of those in other mini PCs. -
Fearless flexibility
Take advantage of expandable and compatible HP mini accessories. Expand storage options, add legacy ports with expansion modules, help secure your device with security mounts, or take back your desk space with stands and work centers. -
Connect to more capabilities
Do more on dual displays with an HDMI port and full HD VGA port, plus use 6 USB ports to plug in all the peripherals you need. -
Easy on
Help keep your investment safe and conveniently power up your desktop mini directly from the keyboard so you don't have to open enclosures or strain for the power button when it's out of reach. -
Speedy storage
Choose a standard hard drive or upgrade to a speedy and reliable solid state drive.
- HP 260 G2 - mini desktop - Core i5 6200U 2.3 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz (, up to 2.8 GHz, (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s - 3D V-NAND technology
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 520
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Hotkey Support, CyberLink PowerDVD BD Edition
- 17.7 cm x 17.5 cm x 3.4 cm
- 1.05 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Value
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8161GH-CG
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45
- Included Accessories
- HP Desktop Mini Vertical Chassis Stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- UL, cUL, FCC, RoHS2
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.4 cm
- 1.05 kg
- 5 °C
- 35 °C
- 15 - 80%
