HP 260 G2 DM Intel Core i5-6200U 4GB 128GB SSD
Quicklinx: C9PKWS00 Mfr#: Y5P67EA#ABU
  • Core i5
The fully functional HP 260 Desktop Mini PC delivers the benefit of space saving design that can grow with your business and is equipped with the essential tools you need at an affordable price.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Power-saving processors
    Do your part to reduce energy use and costs with processors that help consume less than half the energy of those in other mini PCs.
  • Fearless flexibility
    Take advantage of expandable and compatible HP mini accessories. Expand storage options, add legacy ports with expansion modules, help secure your device with security mounts, or take back your desk space with stands and work centers.
  • Connect to more capabilities
    Do more on dual displays with an HDMI port and full HD VGA port, plus use 6 USB ports to plug in all the peripherals you need.
  • Easy on
    Help keep your investment safe and conveniently power up your desktop mini directly from the keyboard so you don't have to open enclosures or strain for the power button when it's out of reach.
  • Speedy storage
    Choose a standard hard drive or upgrade to a speedy and reliable solid state drive.
HP 260 G2 - mini desktop - Core i5 6200U 2.3 GHz - 4 GB - SSD 128 GB - UK
Personal computer - mini desktop
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (, up to 2.8 GHz, (Dual-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s - 3D V-NAND technology
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 520
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Hotkey Support, CyberLink PowerDVD BD Edition
17.7 cm x 17.5 cm x 3.4 cm
1.05 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Value
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Realtek RTL8161GH-CG
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45
HP Desktop Mini Vertical Chassis Stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
UL, cUL, FCC, RoHS2
Power adapter
Power Provided
65 Watt
Efficiency
89%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
17.7 cm
17.5 cm
3.4 cm
1.05 kg
5 °C
35 °C
15 - 80%
