The fully functional HP 260 Desktop Mini PC delivers the benefit of space saving design that can grow with your business and is equipped with the essential tools you need at an affordable price.
Work confidently without the cost
Get the affordably priced business ready desktop mini with the accessories and optional HP services you need plus power saving processors to help lower energy costs. -
Small design, big versatility
The industrial design of the compact desktop mini with flexible mounting options and optional accessories help support a versatile range of use cases from desktop to public computing to digital signage. -
Powered to perform
Accomplish tasks with 4th generation Intel processors and HD 4400 graphics with the option to scale up to Core i5 if your workload demands it. -
Ready to grow
The system of accessories and expansion capabilities of the HP 260 Desktop Mini provide multiple options within one line of products to fit the needs of your diverse work environment.
- HP 260 G1 - mini desktop - Pentium 3558U 1.7 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Pentium 3558U / 1.7 GHz (Dual-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Microsoft Internet Explorer, Cyberlink PowerDVD, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Setup, HP Registration, HP PC Hardware Diagnostics UEFI, Getting Started guide with Windows 8, DTS Sound+, HP Touchpoint Manager
- 17.5 cm x 17.7 cm x 3.4 cm
- 700 g
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Value Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Integrated
- Ethernet Controller
- Realtek RTL8151GH-CG
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card , 1 (total) / 0 (free) x CPU
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 (2 rear) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-in/headphones (1 in front) , 1 x VGA (1 rear) , 1 x DisplayPort (1 rear) , 1 x LAN (Gigabit Ethernet) (1 rear) , 1 x audio line-out (1 rear)
- Included Accessories
- Vertical stand
- Theft/Intrusion Protection
- UL, cUL, FCC, RoHS2
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 700 g
- 5 °C
- 35 °C
- 15 - 80%
