Manage your print environment – and budget – with this advanced, network-ready ePrinter and get up to 50% lower cost per page than lasers. Enjoy easy integration into your office workflow with efficient management and security controls.
Save time, streamline workflows and simplify office tasks
Access print tools and useful business apps via the intuitive control panel and large colour touchscreen.Handle large print jobs using automatic two-sided printing and load up to 500 sheets at once with the optional paper tray.Print up to 2,300 black pages – or up to 1,500 colour pages – from a single high capacity Original HP cartridge.Choose HP for reliable workgroup printing – designed for volumes of up to 1,500 pages a month. -
Conserve resources without sacrificing performance
Use up to 50% less energy than colour lasers – set your printer for savings with Schedule On and Schedule Off.Save up to 50% on paper with automatic two-sided printing.Use up to 50% less supplies and packaging by weight compared with colour laser.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro 251dw - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.8 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - black draft - A4 (210 x 297 mm) , Up to 25 ppm - colour draft , Up to 20 ppm - black laser quality , Up to 15 ppm - colour laser quality
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 480 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, glossy photo paper, matt photo paper, tri-fold brochure paper, card stock
- Total Media Capacity
- 250 sheets
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Networking
- Network adapter
- System Requirements
- Linux, Apple MacOS X 10.6, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 49.4 cm x 46 cm x 23.8 cm
- Printer Type
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD, touch screen, 802.11 b/g access point
- 4.3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 13 sec
- First Print Out Time Colour
- 14 sec
- Processor
- 480 MHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 102 x 152 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 102 x 203 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- Card / Label Sizes
- Hagaki Card (100 x 148 mm), 76.2 x 127 mm, 102 x 152 mm, 127 x 203.2 mm
- Media Weight
- 60 g/m² - 280 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- 250 - 1500 pages
- Networking
- Network adapter
- SSL, Apple Bonjour, LEAP, TLS, 802.1x
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - HP 951 , 1 x ink cartridge (cyan) - HP 951 , 1 x ink cartridge (magenta) - HP 951 , 1 x ink cartridge (yellow) - HP 951
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 38.58 Watt
- Software Included
- Drivers & Utilities, HP ePrint, Google Cloud Print, HP ePrint Wireless Direct
- OS Required
- System Requirements Details
- Windows 7 (32/64 bits) - 1 GHz HD 2 GB , Windows Vista (32/64 bits) - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 750 MB , MacOS X 10.6/10.7/10.8 - Intel Core HD 1 GB
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 5 °C
- 40 °C
- 15 - 80%
- 49.4 cm
- 46 cm
- 23.8 cm
- 8.8 kg
- Width (Shipping)
- 56.7 cm
- Depth (Shipping)
- 30 cm
- Height (Shipping)
- 48.7 cm
- Weight (Shipping)
- 10.7 kg
