HP 251DW OfficeJet Pro Colour InkJet Printer
Quicklinx: 8MXBWS00 Mfr#: CV136A#A81
  • Windows 8 (32/64 bits)
Manage your print environment – and budget – with this advanced, network-ready ePrinter and get up to 50% lower cost per page than lasers. Enjoy easy integration into your office workflow with efficient management and security controls.
  • Save time, streamline workflows and simplify office tasks
    Access print tools and useful business apps via the intuitive control panel and large colour touchscreen.Handle large print jobs using automatic two-sided printing and load up to 500 sheets at once with the optional paper tray.Print up to 2,300 black pages – or up to 1,500 colour pages – from a single high capacity Original HP cartridge.Choose HP for reliable workgroup printing – designed for volumes of up to 1,500 pages a month.
  • Conserve resources without sacrificing performance
    Use up to 50% less energy than colour lasers – set your printer for savings with Schedule On and Schedule Off.Save up to 50% on paper with automatic two-sided printing.Use up to 50% less supplies and packaging by weight compared with colour laser.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet Pro 251dw - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
8.8 kg
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - black draft - A4 (210 x 297 mm) , Up to 25 ppm - colour draft , Up to 20 ppm - black laser quality , Up to 15 ppm - colour laser quality
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Preview Screen Size
4.3"
480 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Media Type
Envelopes, glossy photo paper, matt photo paper, tri-fold brochure paper, card stock
Total Media Capacity
250 sheets
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Network adapter
Linux, Apple MacOS X 10.6, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver
49.4 cm x 46 cm x 23.8 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Status LCD, touch screen, 802.11 b/g access point
Preview Screen Size
4.3"
Wireless
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
13 sec
First Print Out Time Colour
14 sec
Language Simulation
480 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 102 x 152 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 102 x 203 mm
Borderless Photo Sizes
A4 (210 x 297 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Card / Label Sizes
Hagaki Card (100 x 148 mm), 76.2 x 127 mm, 102 x 152 mm, 127 x 203.2 mm
Media Weight
60 g/m² - 280 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Duty Cycle
30000 pages
250 - 1500 pages
Network adapter
Security Protocols & Features
SSL, Apple Bonjour, LEAP, TLS, 802.1x
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - HP 951 , 1 x ink cartridge (cyan) - HP 951 , 1 x ink cartridge (magenta) - HP 951 , 1 x ink cartridge (yellow) - HP 951
Power supply - internal
Frequency Required
50/60 Hz
38.58 Watt
Software Included
Drivers & Utilities, HP ePrint, Google Cloud Print, HP ePrint Wireless Direct
System Requirements Details
Windows 7 (32/64 bits) - 1 GHz HD 2 GB , Windows Vista (32/64 bits) - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 750 MB , MacOS X 10.6/10.7/10.8 - Intel Core HD 1 GB
EPEAT Compliant
EPEAT Silver
ENERGY STAR
5 °C
15 - 80%
49.4 cm
46 cm
23.8 cm
8.8 kg
Width (Shipping)
56.7 cm
Depth (Shipping)
30 cm
Height (Shipping)
48.7 cm
Weight (Shipping)
10.7 kg
