Product
HP 250 G6 Intel Core i5-7200U 8GB 256GB 15.6" Win 10 Pro
Quicklinx: D223WS00 Mfr#: 1WY59EA#ABU
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB, 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£487.49 ex VAT
£584.98 inc VAT
Get connected with the value-priced HP 250 Notebook PC. Complete business tasks with Intel technology and essential collaboration tools loaded on the HP 250. The durable chassis helps protect the notebook from the rigors of the day.
Rest assured that the HP 250 can keep up with assignments on the run. Confidently complete projects with the power of the 7th Gen Intel Core processors. HP, a world leader in PCs helps equip you with a fully functional notebook ready to connect quickly to all your peripherals in the office or at home and designed to fit the needs of business with an RJ-45 port and a VGA port. Back-up and quickly move data to and from your HP 250 with the fast and convenient SD card slot. Get fast connections with Gigabit LAN and WLAN 802.11ac/Bluetooth 4.2 combo.
Let nothing stand in your way: help secure critical data the future of your business. PCs from HP protect you from today's security threats and maximize management and productivity features for business. HP Touchpoint Manager offers users simple tools and services from a single cloud-based solution for managing data and security. The firmware Trusted Platform Module (TPM) provides hardware-based encryption keys to help secure your critical data, e-mail, and user credentials.
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
  • Durable mobile design
    Rest assured that the HP 250 can keep up with assignments on the run. The durable chassis protects the notebook so it looks as professional as you do.
  • Powered for business
    Confidently complete projects with Windows 10 Pro and the power of the latest 7th Gen Intel Core i5/i7, processors with optional DDR4 Memory.
  • Extras that polish the experience
    HP, a world leader in PCs helps equip you with a fully functional notebook ready to connect to all your peripherals and designed to fit the needs of business with an RJ-45 port and a VGA port.
HP 250 G6 - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4
Storage
256 GB - M.2 SSD HP Value
Optical Drive
DVD-Writer
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Dark ash silver, woven texture
38 cm x 25.38 cm x 2.38 cm
1.86 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000 - 2133 MHz
SO-DIMM 260-pin
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s - HP Value
Optical Drive
DVD-Writer
Display
15.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 3168 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi), Miracast
IEEE 802.11, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
41 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
VGA , HDMI , Headphone/microphone combo jack , LAN , 2 x USB 3.1 Gen 1 , USB 2.0
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Support Assistant, HP ePrint, HP PC Hardware Diagnostics UEFI, Recovery Manager Installer, Microsoft Push Button Recovery, CyberLink Power Media Player, HP Touchpoint Manager, HP System Event Utility, HP JumpStart
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.86 kg
ENERGY STAR Certified
Software applications
HP 250 G6 Intel Core i5-7200U 8GB 256GB 15.6 Bundle deal on HP 250 G6 Intel Core i5-7200U 8GB 256GB 15.6" Win 10 Pro
£670.00
saving £8.33
£582.50
Optical Storage: DVD-Writer
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 300 - 500
