Get connected with the value-priced HP 250 G3 Notebook PC. Complete business tasks with Intel technology, essential multimedia tools and Windows 8.1 loaded on the HP 250. The durable chassis helps protect the notebook from the rigors of the day.
Built for mobile use
Rest assured that the HP 250 can keep up with assignments on the run. The durable chassis protects the notebook so it looks as professional as you do.Carry the HP 250 from meeting to meeting. Enjoy the 39,6 cm (15.6") diagonal HD display's great view without sacrificing portability. Choose an AntiGlare display for easier reading in almost any light. -
Powered for business
Confidently tackle projects with the power of Intel's 4th generation Core i3 or i5 dual-core Pentium or Celeron processors.Develop stunning visuals without slowing down your notebook, thanks to Intel's integrated graphics. Alternatively, opt for discrete graphics, for more intense visual creations.Connect with colleagues via the Internet and email at the office or your favorite hotspots with Wi-Fi CERTIFIED WLAN. -
Extras that polish the experience
HP, a world leader in PCs now brings you Windows 8.1 on a full range of products designed to fit the needs of business. Get business-class security to protect data and devices. Your Windows 8.1 experience. Make it better with HP.From training to sales videos, view high quality multimedia right from your notebook using the preinstalled software. The integrated speakers bring you an extraordinary listening experience, too.Give presentations finesse when you connect to larger, HD displays through the HDMI port.
- HP 250 G3 Notebook - 15.6" - Intel Core i3 - 3217U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i3 (3rd Gen) - 3217U / 1.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4000
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 3-cell
- Black licorice
- 37.8 cm x 24.4 cm x 2.53 cm
- 2.19 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Windows 8.1 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i3 (3rd Gen) 3217U / 1.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM76 Express
- Hyper-Threading Technology, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD standard-viewing angle (SVA) anti-glare
Audio & Video
- Graphics Processor
- Camera
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3201-GR
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Ralink RT3290LE
- Network Interface
- 10/100 Ethernet
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 31 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- VGA , HDMI , Headphone/microphone combo jack , LAN , USB 3.0 , 2 x USB 2.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Microsoft Windows Movie Maker, CyberLink Power2Go, Skype, Microsoft Windows Photo Gallery, CyberLink Label Print, Adobe Shockwave Player, HP Games Powered by WildTangent, HP Games, CyberLink Media Suite, HP Connected Photo, HP Utility Center, Snapfish, Skydrive, McAfee LiveSafe (30 days subscription)
- Black licorice
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 2.19 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
