Product
HP 2012 90W Docking Station
Quicklinx: 87G2WS00 Mfr#: A7E32AA#ABU
HP offers a full line of docking stations designed exclusively for select HP Business Notebook platforms so you can maintain the connectivity and comfort of your laptop at a fixed station.
HP 2012 90W Docking Station - docking station
Docking station
26 cm x 16.4 cm x 6.6 cm
1.1 kg
English / United Kingdom
Power adapter - external 90 Watt AC 120/230 V (50/60 Hz)
1 year warranty
EliteBook 2170p, 8440p, 8460p, 8470p, 8560p, 8570p, 8570w, 8740w; Mobile Thin Client mt40, mt41; ProBook 6360b, 640 G1, 6440b, 645 G1, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1, 6540b, 6545b, 655 G1, 6550b, 6555b, 6560b, 6570b
Docking station
26 cm
16.4 cm
6.6 cm
1.1 kg
4 x SuperSpeed USB 3.0 - USB - 9 pin USB Type A , 2 x audio - line-out/headphones - mini-phone 3.5 mm , 1 x network - Ethernet - RJ-45 , 1 x audio - line-In - mini-phone 3.5 mm , 1 x mouse - generic - 3 PIN mini-DIN , 1 x keyboard - generic - 3 PIN mini-DIN , 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - parallel - 25 pin D-Sub (DB-25) , 1 x monitor stand port , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x display / video - DVI-Digital - DVI
Security Slot Type
Kensington security slot
Power Provided
90 Watt
Limited warranty - web support - 1 year , Technical support - phone consulting - 1 year
10 °C
35 °C
HP EliteBook 2170p, 8440p, 8460p, 8470p, 8560p, 8570p, 8570w, 8740w , HP Mobile Thin Client mt40, mt41 , HP ProBook 6360b, 640 G1, 6440b, 645 G1, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1, 6540b, 6545b, 655 G1, 6550b, 6555b, 6560b, 6570b
