HP offers a full line of docking stations designed exclusively for select HP Business Notebook platforms so you can maintain the connectivity and comfort of your laptop at a fixed station.
- HP 2012 90W Docking Station - docking station
- Product Type
- Docking station
- 26 cm x 16.4 cm x 6.6 cm
- 1.1 kg
- Localisation
- English / United Kingdom
- Power
- Power adapter - external AC 120/230 V (50/60 Hz) 90 Watt Power Provided
- 1-year warranty
- Designed For
- EliteBook 2170p, 8440p, 8460p, 8470p, 8560p, 8570p, 8570w, 8740w; Mobile Thin Client mt40, mt41; ProBook 6360b, 640 G1, 6440b, 645 G1, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1, 6540b, 6545b, 655 G1, 6550b, 6555b, 6560b, 6570b
- Product Type
- Docking station
- 26 cm
- 16.4 cm
- 6.6 cm
- 1.1 kg
- Localisation
- 4 x SuperSpeed USB 3.0 - USB - 9 pin USB Type A , 2 x audio - line-out/headphones - mini-phone 3.5 mm , 1 x network - Ethernet - RJ-45 , 1 x audio - line-In - mini-phone 3.5 mm , 1 x mouse - generic - 3 PIN mini-DIN , 1 x keyboard - generic - 3 PIN mini-DIN , 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - parallel - 25 pin D-Sub (DB-25) , 1 x monitor stand port , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x display / video - DVI-Digital - DVI
- Security Slot Type
- Kensington security slot
- Power Device
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 90 Watt
- Limited warranty - web support - 1 year , Technical support - phone consulting - 1 year
- 10 °C
- 35 °C
- Designed For
- HP EliteBook 2170p, 8440p Notebook, 8460p Notebook, 8470p Notebook, 8560p Notebook, 8570p Notebook, 8570w Mobile Workstation, 8740w Mobile Workstation , HP Mobile Thin Client mt40, mt41 , HP ProBook 6360b, 640 G1 Notebook, 6440b, 645 G1 Notebook, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1 Notebook, 6540b, 6545b, 655 G1 Notebook, 6550b, 6555b, 6560b, 6570b
