HP offers a full line of docking stations designed exclusively for select HP Business Notebook platforms so you can maintain the connectivity and comfort of your laptop at a fixed station.
- HP 2012 230W Docking Station - docking station
- Product Type
- Docking station
- 26 cm x 16.4 cm x 6.6 cm
- 1.07 kg
- Localisation
- English / United Kingdom
- Power
- Power adapter - external AC 120/230 V (50/60 Hz) Power Provided
- 1-year warranty
- Designed For
- EliteBook 2170p, 8470w Mobile Workstation, 8570w Mobile Workstation, 8770w Mobile Workstation
- Product Type
- Docking station
- 26 cm
- 16.4 cm
- 6.6 cm
- 1.07 kg
- Localisation
- 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x monitor stand port , 1 x parallel - parallel - 25 pin D-Sub (DB-25) , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - RJ-45 , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x audio - line-In - mini-phone 3.5 mm , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
- Security Slot Type
- Kensington security slot
- Power Device
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Limited warranty - phone consulting - 1 year , Limited warranty - web support - 1 year
- 10 °C
- 35 °C
- Designed For
- HP EliteBook 2170p, 8470w Mobile Workstation, 8570w Mobile Workstation, 8770w Mobile Workstation
