HP offers a full line of docking stations designed exclusively for select HP Business Notebook platforms so you can maintain the connectivity and comfort of your laptop at a fixed station.
- HP 2012 120W Advanced Docking Station - docking station
- Product Type
- Docking station
- 27.05 cm x 26 cm x 6.6 cm
- 1.637 kg
- Localisation
- English / United Kingdom
- Power
- Power adapter - external AC 120/230 V (50/60 Hz)
- Designed For
- EliteBook 2170p, 8440p, 8460p, 8470w, 8560p, 8570w, 8740w; ProBook 6360b, 640 G1, 6440b, 645 G1, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1, 6540b, 6545b, 655 G1, 6550b, 6555b, 6560b, 6570b; ZBook 15 G2 Mobile Workstation, 15 Mobile Workstation
- Product Type
- Docking station
- 27.05 cm
- 26 cm
- 6.6 cm
- 1.637 kg
- Localisation
- Expansion Bays
- 1 (total) / 1 (free) Upgrade Bay
- 4 x SuperSpeed USB 3.0 - 9 pin USB Type A (power only) , 1 x PoweredUSB 2.0 - 4 pin USB Type A , 1 x headphones - line-out - mini-phone 3.5 mm , 1 x audio - line-In - mini-phone 3.5 mm , 1 x parallel - parallel - 25 pin D-Sub (DB-25) , 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 2 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x eSATA / USB 2.0 - USB 2.0 / eSATA , 1 x network - RJ-45 , 1 x docking / port replicator , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x USB 2.0 - 4 pin USB Type A
- Power Device
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 10 °C
- 35 °C
- Designed For
- HP EliteBook 2170p, 8440p, 8460p, 8470w, 8560p, 8570w, 8740w , HP ProBook 6360b, 640 G1, 6440b, 645 G1, 6450b, 6460b, 6465b, 6470b, 6475b, 650 G1, 6540b, 6545b, 655 G1, 6550b, 6555b, 6560b, 6570b , HP ZBook 15 G2 Mobile Workstation, 15 Mobile Workstation
