HP 16GB DDR4-2666 SODIMM Memory
Quicklinx: F6X7WS00 Mfr#: 3TK84AT
Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
  • Flexible, fast scalability
    Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs.
  • Supported by HP
    Protect your investment with the same world-class HP limited warranty you get for your PC.
HP - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Unbuffered
Voltage
1.2 V
HP 938168-001, HP 3TK84AT
Pricing Type
Promo
Elite Slice G2 (SO-DIMM); EliteDesk 705 G4 (SO-DIMM), 705 G5 (SO-DIMM), 800 G4 (SO-DIMM), 800 G5 (SO-DIMM); EliteOne 1000 G1, 1000 G2, 800 G4, 800 G5, 800 G6; ProDesk 400 G5 (SO-DIMM), 405 G4 (SO-DIMM), 600 G4 (SO-DIMM); ProOne 400 G4, 400 G6, 440 G5, 440 G6, 600 G5
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
Pricing Type
Promo
HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Microsoft Teams Room , HP EliteDesk 705 G4(SO-DIMM), 705 G5(SO-DIMM), 800 G4(SO-DIMM), 800 G5(SO-DIMM) , HP EliteOne 1000 G1, 1000 G2, 800 G4, 800 G5, 800 G6 , HP ProDesk 400 G3(SO-DIMM), 400 G5(SO-DIMM), 405 G4(SO-DIMM), 600 G3(SO-DIMM), 600 G4(SO-DIMM) , HP ProOne 400 G3, 400 G4, 400 G6, 440 G5, 440 G6, 600 G3, 600 G5
