HP 15.6" Notebook Privacy Filter
Quicklinx: 9RDRWS00 Mfr#: J7H71AA
Help protect your notebook data from prying eyes with a privacy filter.
  • No compromises
    Retain your screen's crystal clarity through a filter that inhibits a direct view of your content from everyone but you and resists scratches and glare.
  • Easy application
    Use the included adhesive strips and side tabs for easy application, and reuse as needed if you swap between devices.
  • No cutting or resizing required
    Get a precise fit for your screen with a filter that doesn't interrupt access to your webcam.
  • Award-winning support
    Rest easy with a one-year parts replacement limited warranty.
HP - notebook privacy filter
Notebook privacy filter
Notebook Compatibility
15.6"
15.6"
