HP 14" Notebook Privacy Filter
Quicklinx: 9RDQWS00 Mfr#: J6E65AA
Device Type: Laptop
10 in stock
£41.08 ex VAT
£49.29 inc VAT
Help protect your notebook data from prying eyes with a privacy filter.
  • No compromises
    Retain your screen's crystal clarity through a filter that inhibits a direct view of your content from everyone but you and resists scratches and glare.
  • Easy application
    Use the included adhesive strips and side tabs for easy application, and reuse as needed if you swap between devices.
  • No cutting or resizing required
    Get a precise fit for your screen with a filter that doesn't interrupt access to your webcam.
  • Award-winning support
    Rest easy with a one-year parts replacement limited warranty.
HP notebook privacy filter
Notebook privacy filter
Notebook Compatibility
14"
HP 24X G6, 24X G7, 24X G8; EliteBook 1040 G3, 1040 G4, 745 G4, 745 G5, 840 G4, 840 G8, 840r G4, 84X G7; EliteBook x360; Mobile Thin Client mt22, mt45; Pro c645; ProBook 440 G4, 440 G5, 440 G6, 440 G7, 44X G8, 640 G5, 640 G8, 64X G2, 64X G3, 64X G4; ZBook 14u G4; ZBook Firefly 14 G7, 14 G8; ZBook x2
14"
HP 240 G1, 240 G2, 240 G3, 240 G4, 240 G6, 240 G8, 245 G1, 245 G2, 245 G3, 245 G4, 245 G6, 245 G7, 245 G8, 246 G7, 248 G1, 340 G1, 340 G2 , HP EliteBook 1040 G3, 1040 G4, 740 G2, 745 G2, 745 G3, 745 G4, 745 G5, 840 G1, 840 G2, 840 G3, 840 G4, 840 G7, 840 G8, 840r G4, 845 G7, 8470p , HP EliteBook Folio 1040 G1, 1040 G2 , HP EliteBook x360 1040 G7, 1040 G8 , HP Mobile Thin Client mt22, mt45 , HP Pro c645 Chromebook, c645 Chromebook Enterprise , HP ProBook 440 G0, 440 G1, 440 G2, 440 G3, 440 G4, 440 G5, 440 G6, 440 G7, 440 G8, 445 G8, 640 G1, 640 G2, 640 G3, 640 G4, 640 G5, 640 G8, 645 G1, 645 G2, 645 G3, 645 G4 , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 14u G4 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Device Type: Laptop
Brand: HP
Stock Status: In stock
