No compromises
Retain your screen's crystal clarity through a filter that inhibits a direct view of your content from everyone but you and resists scratches and glare. -
Easy application
Use the included adhesive strips and side tabs for easy application, and reuse as needed if you swap between devices. -
No cutting or resizing required
Get a precise fit for your screen with a filter that doesn't interrupt access to your webcam. -
Award-winning support
Rest easy with a one-year parts replacement limited warranty.
