The HP Mobile Print Accessory helps mobile device users print wirelessly without searching for a printer or accessing a company network. Get touch-to-print wireless printing from NFC-capable devices or through a peer-to-peer connection.
An easy solution for printing on the move
Make wireless direct printing easy for everyone in your office.Get secure wireless printing from smartphones, tablets and laptops, using a wireless direct connection – no need for a router or network connection.Compatible with up to 5 simultaneous users. -
Get convenient mobile printing at a touch
Simply touch your mobile device to the accessory and start printing.Enable touch-to-print convenience from NFC-capable mobile devices. -
Enjoy simple and fast installation
Get up and running fast with easy USB plug-and-play installation.Connecting mobile device users to your office printers or MFPs is as simple as attaching this HP Mobile Print Accessory through a USB port. -
Go mobile and stay secure
Keep your network out of reach: The HP Mobile Print Accessory supports wireless direct printing and touch-to-print from mobile devices.Peer-to-peer connection allows mobile users to print without accessing the company network.
- HP 1200w NFC/Wireless Mobile Print Accessory - direct print adapter
- Direct print adapter
- Form Factor
- External
- 67.5 cm x 111.2 cm x 27.5 cm
- 80 g
- Data Link Protocol
- 802.11b/g/n, NFC
- Frequency Band
- 2.4 GHz
- RAM
- 128 MB
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Android 3.2 (Honeycomb), Apple iOS 4.2 or later, Android 4.0.3, Windows 8 (32/64 bits), Android 4.1 (Jelly Bean), Android 4.0.4, Android 4.2 (Jelly Bean), Android 2.3.3 or later, Android 4.3 (Jelly Bean)
- Designed For
- Color LaserJet Enterprise M750, MFP M680; Color LaserJet Managed M651; Color LaserJet Managed Flow MFP M680; LaserJet Enterprise P3015; LaserJet Enterprise Flow MFP M680; LaserJet Managed MFP M680; LaserJet Pro 200 M251, 400 M401, MFP M175, MFP M276, MFP M425, MFP M475, P1102
- Form Factor
- External
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC
- Remote Management Protocol
- IPP
- Frequency Band
- 2.4 GHz
- 128-bit encryption
Processor / Memory
- RAM
- 128 MB
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Encryption Algorithm
- WPA2
- CSA, UL, GOST, CCIB, EN 60950, EN 61000-3-2, EN55022, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, FCC Part 15.247, RSS-210, PSB, FCC CFR47 Part 15 B, LVD, EN 300 328, EN 301 489-17
- Power Device
- External
- Voltage Required
- 2.5 Watt
- Software Included
- HP Embedded Web Server, HP ePrint
- OS Required
- 67.5 cm
- 111.2 cm
- 27.5 cm
- 80 g
- Shipping Width
- 19.2 cm
- Shipping Depth
- 14.4 cm
- Shipping Height
- 6.5 cm
- Shipping Weight
- 0.4 kg
- 0 °C
- 45 °C
- 15 - 95%
- Designed For
- HP Color LaserJet CM1312 MFP, CM1312nfi MFP, CM2320fxi, CM2320n, CM2320nf, CM3530 MFP, CM3530fs MFP, CM6030 MFP, CM6030f MFP, CM6040 MFP, CM6040f MFP, CP1515n, CP2025, CP2025dn, CP2025n, CP2025x, CP3525, CP3525dn, CP3525n, CP3525x, CP6015de, CP6015dn, CP6015n, CP6015x, CP6015xh , HP Color LaserJet Enterprise CM4540 MFP, CM4540f MFP, CM4540fskm MFP, CP4025dn, CP4025n, CP4525dn, CP4525n, CP4525xh, CP5525dn, CP5525n, CP5525xh, M651dn, M651n, M651xh, M750dn, M750n, M750xh, MFP M680dn, MFP M680f , HP Color LaserJet Managed M651dnm, M651xhm , HP Color LaserJet Managed Flow MFP M680zm , HP Color LaserJet Pro CP1025, CP1025nw, CP1525n, CP1525nw, MFP M176n, MFP M177fw, MFP M476dn, MFP M476dw, MFP M476nw , HP LaserJet M1120 MFP, M1319f MFP, M1522n MFP, M1522nf MFP, M4349x MFP, M9040 MFP, M9050 MFP, P2035, P2035n, P2055, P2055d, P2055x, P4014, P4014dn, P4014n, P4015dn, P4015tn, P4015x, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise M4555f MFP, M4555h MFP, P3015, P3015d, P3015dn, P3015n, P3015x , HP LaserJet Enterprise Flow MFP M680z , HP LaserJet Managed MFP M680dnm , HP LaserJet Pro 200 M251n, 200 M251nw, 400 M401a, 400 M401d, 400 M401dn, 400 M401dne, 400 M401dw, 400 M401n, 400 M451dn, 400 M451dw, 400 M451nw, CM1415fn, CM1415fnw, M1132 MFP, M1212nf MFP, MFP M125a, MFP M125nw, MFP M127fn, MFP M127fw, MFP M175a, MFP M175nw, MFP M276n, MFP M276nw, MFP M425dn, MFP M425dw, MFP M475dn, MFP M475dw, P1102, P1102s, P1102W, P1109, P1109W, P1566, P1606DN , HP Officejet 100, 100 L411b, 150 Mobile L511a , HP Officejet Enterprise Color X555dn, X555xh
