Original HP Ink Cartridges reliably deliver laser-quality, durable documents page after page. Get the value you expect from cartridges specially designed to work with your HP printer for projects at home, work and school.
Keep your printing needs covered
Represent your best work with Original HP inks – designed for consistent, standout results you can count on.
Get your prints noticed
Make an impression with Original HP inks – designed to consistently deliver standout colour page after page.
The quality you need, at a great value
Avoid wasting money on problem prints. Original HP inks are designed to deliver pages you can use.
Printing made easy
From high-capacity cartridges to multi-packs, HP has the right combination to fit your printing needs.
Designed to work the first time, every time
Be assured that Original HP Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together. Better results
Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Share your prints with pride
Show off your printing projects. Create documents you'll be proud to share – using Original HP inks. -
Optional high-yield cartridges offer a better value
Print more for less with optional Original HP high-yield ink cartridges.
- HP 62 - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black
- Yield
- Up to 200 pages
- Packaging Type
- Blister
- Compatible with
- ENVY 5542, 5545, 5640, 5643, 5660, 5663, 7640, 7644; Officejet 200, 250 Mobile, 5740, 5742, 5742 Printer, 5744, 8040, 8040 with Neat
- Shipping Weight
- 0.1 kg
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black
- Included Qty
- 1-pack
- Yield
- Up to 200 pages
- Packaging Type
- Blister
- Compatible with
- HP ENVY 5542, 5545, 5640, 5643, 5660, 5663, 7640, 7644 , HP Officejet 200, 250 Mobile, 5740, 5742, 5742 Printer, 5744, 8040, 8040 with Neat
