The beautifully designed, thin, and light HP EliteBook x360 830 G7 adapts to all the ways you create, connect, and collaborate. Meet the demands of your multi-task, multi-place workday with this powerful and highly secure convertible PC.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
Fast performance, connectivity, and responsiveness
Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption. -
Keep your PC's security protections in place
Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen3 which identifies, quarantines, and provides reporting on attackers trying to kill processes.
- HP EliteBook x360 830 G7 - 13.3" - Core i5 10210U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.3" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- 3-cell - up to 22 hours
- Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
- Security
- Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader, smart card reader
- 30.75 cm x 20.5 cm x 1.79 cm
- 1.31 kg
- Localisation
- Environmental Standards
- TCO Certified Notebooks 8, ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), HP Value
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 5
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, gesture function, precision touchpad, glass clickpad, DuraKeys
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Miracast, dual stream (2x2), MU-MIMO
- IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Technology
- 3-cell lithium polymer
- Capacity
- 53 Wh
- Run Time
- Up to 22 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- 2 x USB-C 3.1 (supports Thunderbolt) , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Support Assistant, HP Hotkey Support, Windows Defender, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, Ivanti Management Suite, HP BIOSphere Gen5, HP Cloud Recovery, HP Sure Sense, HP Sure Recover Gen3, HP WorkWell, HP Client Management Script Library, HP Client Security Manager Gen6, HP SureStart Gen6, HP SureRun Gen3, HP Multi-Factor Authenticate Gen3
- Case Material
- Aluminum
- Integrated Options
- Security
- Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, BIOS Update via Network, ultra-slim, HP Secure Erase
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 45 Watt Smart nPFC AC Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP, AUS/NZ
- Localization
- 1.31 kg
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
HP Slim Ultrabook Messenger | In Stock | £44.24 |
HP 65W Smart AC Adapter | In Stock | £17.92 |
HP 90W Smart AC Adapter | In Stock | £33.45 |
HP 65W Smart AC Adapter | In Stock | £22.18 |
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook | In Stock | £116.59 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £78.10 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £126.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £109.23 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return | In Stock | £167.33 |
HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) | In Stock | £259.59 |
HP 3 Year Premium Care Notebook service | In Stock | £138.46 |
HP Carepack 5y Travel NextBusDay Notebook Only SVC | In Stock | £410.49 |
Other bundles (19)
HP Slim Wireless Keyboard and Mouse | In Stock | £53.26 |
HP Presenter MouseRemote control | In Stock | £74.35 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Z43 42.5" 3840x2160 5ms HDMI DisplayPort Mini DisplayPort USB-C LED Monitor | In Stock | £711.11 |
HP USB-C to RJ45 Adapter | In Stock | £21.65 |
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor | In Stock | £944.44 |
HP USB-C to USB 3.0 | In Stock | £20.71 |
HP P24h G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £152.17 |
HP P22h G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £180.00 |
HP P19b G4 19" 1366x768 5ms VGA HDMI LED Monitor | In Stock | £115.00 |
HP P24 G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £127.78 |
HP P24q G4 23.8" 2560x1440 5ms VGA HDMI IPS LED Monitor | In Stock | £189.00 |
HP P27q G4 27" 2560x1440 5ms VGA HDMI IPS LED Monitor | In Stock | £243.00 |
HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor | In Stock | £188.89 |
HP E22 G4 21.5" 1920x1080 5ms VGA USB HDMI Full HD IPS Monitor | In Stock | £185.00 |
HP E24 G4 24" 1920x1080 5ms HDMI VGA LED Monitor | In Stock | £198.70 |
HP E23 G4 FHD 1920X1080 5ms HDMI VGA USB | In Stock | £193.00 |
HP E24I G4 1920X1200 24" 5ms VGA HDMI | In Stock | £226.36 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £197.40 |
