HP - Disk drive - DVD-RW - USB - External
CLEARANCE!
Clearance
Quicklinx: CKLQWS00 Mfr#: F2B56ET
Drive Type: DVD writer
Enclosure Type: External
Interface: USB
Type: Disk drive
  • DVD-RW
More than 50 in stock
£39.09 ex VAT
£46.90 inc VAT
Connect the HP External USB DVD/RW to any available USB port on your PC to get immediate read/write access to your optical media.
Back up your data, move files, enjoy your multimedia, and read and write CDs and DVDs2 to your heart’s content with a compact external ODD.
Keep your workspace tidy and add an ODD only when you need it. Connect the USB-powered drive to any USB 2.0 or 3.0 port on your PC and you’re ready to go. No additional AC adapter is required.
Enjoy the reassurance of a one-year parts replacement limited warranty.
HP DVD-RW drive - USB - external
DVD-RW drive - external
USB
Optical Storage
DVD-RW
HP 24X G7, 24X G8, 25X G8, 340 G7, 470 G8; EliteBook 83X G8, 84X G8, 85X G8, 8770; EliteBook x360; Mobile Thin Client mt32; Pro c640 G2, c645; ProBook 430 G8, 44X G8, 45X G8, 630 G8, 635, 650 G8; ProBook x360; ZBook Power G7, Power G8, Studio G8; ZBook Firefly 14 G8, 15 G8; ZBook Fury 15 G8, 17 G8
USB
Optical Storage
DVD-RW
1 x USB
HP 240 G8, 245 G7, 245 G8, 246 G7, 250 G7, 250 G8, 255 G7, 255 G8, 256 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7, 470 G8 , HP Chromebook 11 G6, 11 G7, 11 G8, 11A G6, 11A G8, 14 G5, 14 G6, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G2, 11 G3, 14 G1 , HP Elite c1030 Chromebook, c1030 Chromebook Enterprise , HP EliteBook 1050 G1, 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 830 G6, 830 G7, 830 G8, 835 G7, 835 G8, 840 G5, 840 G6, 840 G7, 840 G8, 840r G4, 845 G7, 845 G8, 850 G5, 850 G6, 850 G7, 850 G8, 855 G7, 855 G8, 8770w , HP EliteBook x360 1030 G7, 1030 G8, 1040 G7, 1040 G8, 830 G5, 830 G6, 830 G7, 830 G8 , HP EliteDesk 705 G4 , HP Mobile Thin Client mt22, mt32, mt46 , HP Pro c640 Chromebook, c640 G2 Chromebook, c640 G2 Chromebook Enterprise, c645 Chromebook, c645 Chromebook Enterprise , HP ProBook 430 G6, 430 G7, 430 G8, 440 G6, 440 G7, 440 G8, 445 G6, 445 G7, 445 G8, 445r G6, 450 G6, 450 G7, 450 G8, 455 G5, 455 G6, 455 G7, 455 G8, 455r G6, 630 G8, 635 Aero G7, 635 Aero G8, 640 G4, 640 G5, 640 G8, 645 G4, 650 G4, 650 G5, 650 G8 , HP ProBook x360 11 G3, 11 G4, 11 G5, 11 G6, 11 G7, 435 G7, 435 G8 , HP ProDesk 600 G4 , HP Spectre x360 15-ch006tx , HP ZBook 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Create G7, Power G7 Mobile Workstation, Power G8 Mobile Workstation, Studio G5 Mobile Workstation, Studio G7 Mobile Workstation, Studio G8 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 15 G7 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook Fury 15 G7 Mobile Workstation, 15 G8 Mobile Workstation, 17 G7 Mobile Workstation, 17 G8 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Interface: USB
Type: Disk drive
Brand: HP
Stock Status: In stock
Stock Status: Clearance
