Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP PCs.
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your PC.
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements. -
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs. -
Supported by HP
- HP - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Unbuffered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP P1N54AT
- 1-year warranty
- Designed For
- HP 260 G2; Elite Slice, Slice for Meeting Rooms; EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop); EliteOne 800 G2; ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop); ProOne 400 G2, 600 G2; Retail System MP9 G2; RP9 G1 Retail System 9015, 9018, 9118
- Capacity
- 8 GB
- Upgrade Type
- System specific
- HP P1N54AT
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Unbuffered
- Voltage
- 1.2 V
- 1-year warranty
- Designed For
- HP 260 G2 , HP Elite Slice, Slice for Meeting Rooms , HP EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop) , HP EliteOne 800 G2 , HP ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop) , HP ProOne 400 G2, 600 G2 , HP Retail System MP9 G2 , HP RP9 G1 Retail System 9015, 9018, 9118
