HP - DDR4 - 8 GB - DIMM 288-pin
Quicklinx: CKK2WS00 Mfr#: P1N52AT
Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
Dual channel configuration - HP Desktops feature motherboards designed with two memory channels instead of a single channel.
Reduce system latencies and significantly improve your system performance with dual channel memory configurations by utilizing the theoretical bandwidth of two memory modules instead of one.
Get fast start-up times, meet everyday workloads head on, and run more programs simultaneously with speeds up to 2133 MT/s.
Your performance is our business. Each HP Memory model undergoes a rigorous supplier qualification processes for ensured quality and reliability in a variety of networked environments.
HP - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Unbuffered
Voltage
1.2 V
HP P1N52AT
1-year warranty
HP 280 G2; EliteDesk 705 G3, 800 G2; ProDesk 400 G3, 490 G3, 600 G2
8 GB
Upgrade Type
System specific
HP P1N52AT
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
1-year warranty
HP 280 G2 , HP EliteDesk 705 G3, 800 G2 , HP ProDesk 400 G3, 490 G3, 600 G2
