HP - DDR4 - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200
Quicklinx: CKM5WS00 Mfr#: T9V40AT
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2400MHz
Registered/Buffered: Registered
Hurry, only 1 left in stock!
£391.61 ex VAT
£469.93 inc VAT
Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP Workstations.
Benefit from integrated ECC
Help avoid errors that can corrupt data sets and introduce system issues with Error Checking and Correcting technology that corrects single-bit memory errors.
  • Flexible, fast scalability
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP Workstations.
  • Benefit from integrated ECC
  • Supported by HP
    Protect your investment with the same world-class HP limited warranty you get for your HP Workstation.
HP - DDR4 - 16 GB - DIMM 288-pin - registered
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
HP T9V40AT, HP 852264-001
Workstation Z440, Z640, Z840
16 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Chips Organization
2048 x 4
Voltage
1.2 V
HP Workstation Z440, Z640, Z840
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2400MHz
Brand: HP
Price Range Ex VAT: 300 - 500
