Honeywell W1 Wi-Fi Water Leak and Freeze Detector
Quicklinx: D7M1WS00 Mfr#: W1KS
£58.33 ex VAT
£69.99 inc VAT
Leaks and frozen pipes can cause serious damage to customers' homes. But with the Honeywell W1 Wi-Fi Water Leak and Freeze Detector, they'll be notified swiftly on their smart device if there's a problem, so they can act quickly and avoid potential costly repairs. Battery-operated and compact, this reliable solution can be kept close at hand to offer customers low-maintenance peace of mind.
Honeywell Home App
Stay in control of your home comforts, even when you're away.
One app for your connected home:
We’re saying "goodbye" to the Honeywell Lyric app and "hello" to the Honeywell Home app, to make room for big improvements.The Honeywell Home app has more features, like the usability upgrades you’ve asked for, one-touch dashboard and improved geofence. It provides a better experience for you by bringing our T6 thermostats, security and awareness products together under one roof – onto a single app on your mobile device.
With the Honeywell Home app, you can take control of your home comforts and always know what's going on at home, at the touch of a button. Available for Android and iOS devices, it puts you in charge of your smart home devices, wherever you are.
One Touch Dashboard - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Simple Setup - Getting started is quick and easy as the app guides you through each simple step. It’s equally easy to use, with pre-configured scheduling and a wide choice of settings.
Family Access - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Location Based Control (Geofencing) - Our geofencing technology just got smarter: More accurate location awareness means more precise performance. Using geofencing technology, the Honeywell Home app keeps track of your location and knows when you’re returning - adapting your smart home technology to suit your needs. Your thermostat will automatically set to your preferred temperature, ensuring your home is comfy and cosy on your arrival. Home or away modes will also be enabled on your C1 and C2 Security Cameras depending on your location, automatically turning the camera on when you leave the house, then off when you come home. So it’s always in tune with your movements.
Programmable - The Honeywell Home app is as flexible as you are. So you can program your comforts for the week ahead — and adjust them easily if your plans change suddenly.
Always know what's going on at home - Our indoor security camera lets you watch what’s happening at home, so if something happens when you’re not there, you can take action.
Honeywell W1 Water Leak and Freeze Detector - multipurpose sensor
Multipurpose sensor
Functions
Temperature measuring, water leak detection
Power Source
Wireless - 802.11b/g
Frequency Band
2.4 Ghz
7.8 cm x 3.2 cm x 7.8 cm
Multipurpose sensor
Functions
Power Source
Wireless - IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 Ghz
Audio alert, text alerts, 100dB buzzer
Screw, 3 AA batteries, sensor cable (1.2 m)
Battery Required
3 x AA type
Warranty
IP44
7.8 cm
3.2 cm
7.8 cm
Type: Multipurpose sensor
Brand: Honeywell
Price Range Ex VAT: 50 - 100
