Honeywell W1 Wi-Fi Water Leak and Freeze Detector Sensor Cable
Quicklinx: D7M3WS00 Mfr#: W1AS
Honeywell W1 1.2m Extension Cable for Water Leak and Freeze Detector (https://www.shop.bt.com/products/honeywell-lyric-w1-wi-fi-water-leak-and-freeze-detector-w1ks-D7M1.html)
  • Connect from anywhere
    Control the Lyric T5 Wi-Fi Thermostat using your smartphone or tablet so it knows when you're coming home and can make sure your home is exactly how you like it when you arrive.
  • Automatic control
    Geofence technology helps make you comfortable by using your smartphone's location to know when you're away and when you return.
  • Connect your home
    The Lyric T5 Wi-Fi Thermostat is a Wi-Fi connected platform, designed to help make your home smarter and more comfortable than ever.
Honeywell W1 - flood sensor extension cable
Flood sensor extension cable
Honeywell W1 Water Leak and Freeze Detector
1.2 m extension length
