Honeywell Voyager 1200g Barcode Scanner
Quicklinx: BJMGWS00 Mfr#: 1200G-1USB-1
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
10 in stock
£76.68 ex VAT
£92.01 inc VAT
Built on the platform of the single-line laser scanner, Honeywell's Voyager 1200g delivers aggressive scan performance on virtually all linear bar codes, including poor quality and damaged codes. Updated object detection, and automatic in-stand detection and configuration enable class-leading presentation scanning that maximizes throughput. Superior scan performance matched with a reliable design combine to provide a versatile linear scanning solution suitable for a wide variety of applications.
The intuitive Voyager 1200g provides fast and reliable scanning of linear bar codes across its full working range, minimizing the need for user training. Whether poorly printed, smudged or faded, the Voyager 1200g decodes difficult-to-read bar codes with ease. The Voyager 1200g also excels at scanning high density bar codes with resolution down to 3.5-mil, eliminating the need to purchase specialty scanners.
A recessed button protected by an integrated rubber co-mold minimizes the impact of accidental drops. Added durability is provided in the form of a protected, scratch-resistant glass window and an IP42-rating. The Voyager 1200g provides outstanding scan performance and reliability for end users seeking an exceptional linear scanning solution.
  • Outstanding scan performance on poor quality and damaged bar codes
    It maintains productivity by providing a worry-free linear scanning solution that minimizes the need for manual data entry.
  • Class-leading presentation scanning
    It increases throughput by providing object detection and automatic in-stand detection and configuration.
  • Multi-interface
    It minimizes costs by delivering support for USB, keyboard wedge, and RS232 interfaces in a single scanner.
  • Superior out-of-box experience
    It simplifies set up with tool-free stand assembly; automatic in-stand detection and configuration; and automatic interface detection and configuration.
  • Contemporary, ergonomic design
    It ensures operator comfort and productivity by incorporating an integrated finger groove in a sleek, lightweight industrial design that fits well in most hands.
  • CodeGate technology
    It enables users to ensure that the desired bar code is scanned before transmitting data, making the scanner ideal for use in menu scanning applications.
Honeywell Voyager 1200g - barcode scanner
Barcode scanner - handheld - USB - decoded
Ivory
Minimum Bar Width
3.5 mil
Scan Element Type
Linear imager
Scan Speed
100 line / sec
Wired
18 cm x 6.6 cm x 9.7 cm
125 g
5-year warranty
Ivory
Barcode
Interface Type
USB
Minimum Bar Width
3.5 mil
Scan Element Type
Linear imager
Scan Mode
Single-pass
Scan Speed
100 line / sec
Max Working Distance
28.1 cm
Skew (Degrees)
60
Pitch (Degrees)
60
Print Contrast Signal (PCS)
10%
Decode Capability
GS1 DataBar
TTL Decoding
Decoded
Wired
CodeGate
1 x USB - Type A
Stand
1 x USB cable - external - 3 m
RoHS, WEEE, cULus
Electric Current Required
140 mA (operating), 70 mA (standby)
18 cm
6.6 cm
9.7 cm
125 g
Limited warranty - 5 years
50 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Honeywell
Price Range Ex VAT: 50 - 100
