Honeywell Evo Wireless Smoke Sensor
Quicklinx: D3TGWS00 Mfr#: DFS8MS
Type: Smoke sensor
Compatible With: IFTTT
£41.66 ex VAT
£49.99 inc VAT
The wireless smoke sensor DFS8MS alerts you to the presence of smoke, with a built-in sounder.
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Honeywell Evohome DFS8MS - smoke sensor
Smoke sensor
Power Source
Wireless
Frequency Band
868 MHz
White
12 cm x 12 cm x 4.5 cm
Smoke sensor
Power Source
Wireless
Max Range Open Space
1000 m
Frequency Band
868 MHz
85dB siren
White
Battery Required
1 x CR123A
12 cm
12 cm
4.5 cm
241 g
-10 °C
55 °C
15 - 90% (non-condensing)
Type: Smoke sensor
Brand: Honeywell
Price Range Ex VAT: 0 - 50
