Honeywell EVO Wireless Remote Control Key Fob
Quicklinx: D3WJWS00 Mfr#: TCC800MS
Type: Remote control
Compatible With: IFTTT
£18.15 ex VAT
£21.78 inc VAT
Arm or disarm your system from up to 150 metres, with just one push of a button. Disarm the system from your car – or partially arm it from your bed. There’s a panic button in case of an emergency. LED indicators show the system status, making it even easier to use.
  • Arm, partially arm and disarm the system
  • LED indications for user feedback (low battery, system status – arm, disarm, partial arm)
  • Panic function
  • One battery (CR2032) supplied
  • 4 year battery life
  • 56 x 48 x 9mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Honeywell remote control
Remote control
Enclosure Colour
4.8 cm x 0.9 cm x 5.6 cm
19 g
Radio
CR2032
Remote control
4.8 cm
0.9 cm
5.6 cm
19 g
Enclosure Colour
Radio
IP32
-10 °C
55 °C
CR2032
Brand: Honeywell
Price Range Ex VAT: 0 - 50
