Honeywell EVO Wireless Home Alarm Kit incl Camera, Sensors & Tags
Quicklinx: D3THWS00 Mfr#: HS912S
Type: Home security system
Compatible With: IFTTT
£149.99 ex VAT
£179.98 inc VAT
Smart Wireless Home Alarm Kit with Camera
Contains:
1 x evohome security hub
1 x Wireless motion sensor with colour camera
2 x Wireless door and window sensor
1 x Wireless, contactless tag reader with built in siren
2 x Tags
1 x Ethernet cable
All batteries included
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Honeywell Evohome HS912S - home security system
Functions
Siren
Power Source
Battery, power adapter
Package Content
Door and window sensor, motion sensor, security hub
Wireless, wired - Ethernet - Cellular
Functions
Siren
Power Source
Package Content
Components
Security hub , Motion sensor , Door and window sensor , Camera , Tag reader
Mobile Network Supported
GPRS
Network cable, 2 tags
Brand: Honeywell
Price Range Ex VAT: 100 - 150
