Honeywell Dolphin 70e Data Collection Terminal - Windows Embedded Handheld 6.5 Pro 1GB 4.3"
Quicklinx: CBR4WS00 Mfr#: 70E-L00-C111SE2
The Dolphin 70e, Honeywell's enterprise digital assistant, successfully marries the size, style and usability of a consumer device with the reliability and longevity of a traditional rugged hand-held. Engineered with premium materials and clean lines, the form factor of the Dolphin 70e elegantly lends itself to personal device usage while also meeting the challenges found in the unpredictable surroundings of the mobile enterprise.
Along with the aesthetic details, the Dolphin 70e was also built to deliver years of reliable operation. Incorporating corning gorilla glass, the device's touch screen is exceptionally resistant to damage. The IP67-rated housing protects against dust and water immersion and for added versatility, the Dolphin 70e can be operated in extreme temperatures as low as -20° C (-4° F) minimizing downtime associated with conditions.
Businesses can also capitalize on the flexible platform supplied by the Dolphin 70e which can be customized according to use case with Microsoft Windows or Google Android operating systems. The crystal clear 4.3" display can be seen in virtually any lighting condition, including outdoors, and is equipped with the same capacitive touch screen technology used in advanced smartphones, enabling the use of two-finger gestures for device operation. Further, the offering's integrated imager provides bar code scanning performance superior to that of the camera scanning applications that are currently available in the market. Compatible with Honeywell's turnkey remote management solution, Remote MasterMind, the Dolphin 70e can be tracked and managed in real time from any location, reducing the total cost of ownership incurred with mobile deployments.
Impeccably positioned where emotional elements and rational demands meet, the Dolphin 70e effortlessly enables enterprises to stay on trend without sacrificing performance.
  • Aesthetically pleasing and pocketable
    It offers attractively designed to increase ease of adoption by brand conscious end users.
  • Beyond reliable
    It integrates corning gorilla glass for display damage resistance, and an IP67-rated housing designed to withstand multiple 4' drops to concrete.
  • Crystal clear touch screen display
    Capacitive touch technology and readability in various lighting conditions combine to provide an offering that is perfect for inside or outside use cases.
  • Fast and reliable wireless connectivity
    Delivers full wireless coverage for applications inside and outside of the four walls, allowing real-time access to critical data.
  • Remote MasterMind ready
    Extends mobile workforce capabilities and reduces total cost of ownership by providing a turnkey remote device management solution.
Honeywell Dolphin 70e - data collection terminal - Win Embedded Handheld 6.5 Pro - 1 GB - 4.3"
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Handheld 6.5 Professional
Display
4.3" colour TFT - 480 x 800 - Multi-Touch
Texas Instruments
Processor Clock Speed
1 GHz
Storage
1 GB
RAM
512 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel
Barcode Reader
Yes (2D imager)
Battery Run Time
Up to 6 hours
7.3 cm x 1.8 cm x 13.4 cm
204 g
English / Worldwide
1-year warranty
Operating System
Display
4.3" colour TFT
Resolution
480 x 800
Touchscreen
Multi-Touch
Corning Gorilla glass
Texas Instruments
1 GHz
Storage
1 GB
RAM
512 MB
microSD, microSDHC
Communications
Security Protocols & Features
LEAP, WEP, WPA-PSK, TLS, WPA2, 802.1x, TKIP, TTLS
Rear Camera
Sensor Resolution
5 Megapixel
Light Source
Flash
Multimedia
Audio
Microphone, speaker
Input Device
4 front panel programmable buttons
Barcodes
Barcode Reader
Scan Element Type
2D imager
Expansion and Connectivity
Expansion Slots
1 x microSDHC
1 x Micro-USB , 1 x headset
Installed Qty (Max Supported)
1
Lithium Ion
1670 mAh
Run Time
Up to 6 hours
Sensors
Accelerometer, ambient light sensor, proximity sensor
Vibrating Alert
UL, CCC, FCC, RoHS, WEEE, IEC 60068-2-32, cULus, IP67, ISO 9001:2008
English / Worldwide
7.3 cm
1.8 cm
13.4 cm
204 g
Limited warranty - 1 year
-20 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
