- Lightweight Pocket-Size Design: Provides instinctive data entry and comfortable single-handed use in a compact form factor
- Durable Construction: Minimizes device repair and replacement costs with a design tested to withstand four foot drops to concrete and hundreds of 0.5 meter tumbles
- Real-Time Wireless Communication: Incorporates integrated GSM/GPRS cellular, 802.11 b/g/n WiFi, Bluetooth and GPS technologies, allowing real-time communications, access to critical data, and use of location-based services,wherever business is conducted
- Versatile Data Collection: Features an integrated 1D and 2D scan engine, a 5MP color camera, and a 2.8 inch color display, allowing manual processes to be automated
- Optimized Voice Technology: Eliminates the need for workers to carry a separate phone and has the ability to connect to a Bluetooth headset during calls
- Remote MasterMind⢠Ready: Reduces total cost of ownership by providing a turnkey remote device management solution that easily manages and tracks usage of installed devices
- Service Made Simple⢠Service Plans: Offers comprehensive, hassle-free protection on the device investment for up to three years after purchase, lowering the total cost of ownership
Lightweight pocket-size design
It provides instinctive data entry and comfortable single-handed use in a compact form factor. -
Durable construction
It minimizes device repair and replacement costs with a design tested to withstand four foot drops to concrete and hundreds of 0.5 meter tumbles. -
Real-time wireless communication
It incorporates integrated GSM/GPRS cellular, 802.11 b/g/n WiFi, Bluetooth and GPS technologies, allowing real-time communications, access to critical data, and use of location-based services, wherever business is conducted. -
Versatile data collection
It features an integrated 1D and 2D scan engine, a 5-megapixel color camera, and a 2.8-inch color display, allowing manual processes to be automated. -
Optimized Voice technology
It eliminates the need for workers to carry a separate phone and has the ability to connect to a Bluetooth headset during calls. -
Remote MasterMind ready
It reduces total cost of ownership by providing a turnkey remote device management solution that easily manages and tracks usage of installed devices.
- Honeywell Dolphin 60s Scanphone - data collection terminal - Win Embedded Handheld 6.5 Pro - 512 MB - 2.8" - 3G
- Product Type
- Data collection terminal
- Operating System
- Microsoft Windows Embedded Handheld 6.5 Professional
- Display
- 2.8" colour - 240 x 320
- Processor
- Texas Instruments AM3715
- Processor Clock Speed
- 800 MHz
- Storage
- 512 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Cellular Technology
- 3G
- Cellular Protocols
- GSM, GPRS, UMTS, EDGE, HSPA+
- Wireless Connectivity
- 802.11b/g/n, Bluetooth 2.1 EDR
- Rear Camera
- 5 Megapixel focus: automatic
- Navigation System
- GPS
- Barcode Reader
- Yes (2D imager)
- 6.6 cm x 2.87 cm x 13.6 cm
- 246.6 g
- 1-year warranty
- Product Type
- Operating System
Display
- 2.8" colour
- Resolution
- 240 x 320
- Processor
- 800 MHz
- Storage
- 512 MB
- RAM
- 256 MB
Communications
- 3G
- LEAP, WEP, WPA-PSK, WPA2, 802.1x, TKIP, EAP-TTLS, EAP-TLS, PEAP, MD5
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- Flash
Navigation System
- Receiver
- GPS
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, QWERTY keyboard
- Keys Qty
- 46
Barcodes
- Barcode Reader
- Scan Element Type
- 2D imager
Software
- Preloaded Software
- Remote MasterMind for Mobility, Honeywell Powertools and Demos
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x Micro-USB , 1 x headset
- Technology
- Lithium Ion
- Capacity
- 3340 mAh
- Drop-resistant, resistive touch screen
- CCC, FCC, RoHS, IEC 60068-2-32, cULus, ISO 9001:2000, IP54
- 6.6 cm
- 2.87 cm
- 13.6 cm
- 246.6 g
- Limited warranty - 1 year
- -10 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
