Honeywell 1902G Barcode Scanner 1D PDF417
Quicklinx: 9PMNWS00 Mfr#: 1902GSR-2USB-5
Xenon 1902, Honeywell's area-imaging technology, is redefining the standard for hand-held scanners. Featuring a custom sensor that is optimized for bar code scanning, Xenon 1902 offers industry-leading performance and reliability for a wide variety of applications that require the versatility of area-imaging technology plus the freedom of Bluetooth wireless connectivity. Powered by Adaptus Imaging technology 6.0, Xenon 1902 delivers superior bar code scanning and digital image capture. Xenon 1902 incorporates a revolutionary decoding architecture that combines Adaptus Imaging technology 5.5 and Omniplanar's SwiftDecoder software along with a custom sensor, enabling extended depth of field, faster reading, and improved scanning performance on poor quality bar codes.
Honeywell Xenon 1902 - Standard Range - USB Kit - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 - decoded
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Sensor Resolution
838 x 640
Wireless
Wireless Connectivity
Bluetooth 2.1
Lithium Ion
7.1 cm x 10.4 cm x 16 cm
214 g
3-year warranty
Barcode
Interface Type
Bluetooth 2.1
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Sensor Resolution
838 x 640
Scan Mode
Single-pass
Skew (Degrees)
65
Pitch (Degrees)
45
Print Contrast Signal (PCS)
20%
Decode Capability
Code 39, QR code, UPC, PDF417, Data Matrix
TTL Decoding
Decoded
Wireless
Adaptus Imaging Technology
Bluetooth 2.1
Cradle
1 x USB cable - 3 m
Bluetooth Class 2, IP41
External
Lithium Ion
Software
Software Included
MasterMind, Omniplanar SwiftDecoder, TotalFreedom 2.0
7.1 cm
10.4 cm
16 cm
214 g
Limited warranty - 3 years , Limited warranty - battery - 1 year
50 °C
0 - 95% (non-condensing)
Drop Specification
1.8 m to concrete
