Hive Window or Door Sensor
Enjoy life to the full, knowing that everything’s safe at home with our Hive Window or Door Sensor.
- Get notifications if a door or window is opened when you’re away
- Attach and set up in seconds
- Use with Hive Actions to save on heating and lighting
Enjoy your night out
Check you shut the bedroom window properly on the Hive app.
Know when your kids are home
Our Window or Door Sensor will send you a notification when the front door is opened or closed.
Turn lights on automatically
Connect your sensor with the smart light bulbs using Hive Actions. So they switch on automatically, the moment you open a door. -
Travel back in time
Been away for a couple of days? You can see when doors or windows have been opened or closed, going back seven days. Or subscribe to HomeShield for 30-days of event history. -
Know when someone's home
The moment your Hive Window or Door Sensor detects activity it sends a notification to your smartphone, tablet and watch. Keep the whole family in the know using multi-device notifications with Hive HomeShield. -
Raise the alarm
If your HomeShield is in Away or Sleep mode, use your sensor to trigger the alarm when a door or window is opened.
