Hive View Camera - White/Champagne Gold
Quicklinx: D9YJWS00 Mfr#: UK7001720
Type: Indoor Camera
Colours:
Hurry, only 1 left in stock!
£157.50 ex VAT
£189.00 inc VAT
Express delivery Delivered on Tuesday
Hive View
Stylish new smart indoor camera, packed with must-have features like HD livestreaming and person detection.
Stay close with two-way audio
Two-way audio is a great way to stay in touch with home. Whether it's a quick hello to the kids or telling the dog to behave, just tap the mic button on your Hive app.
Peace of mind when you're away
Hive View starts recording when it detects motion or sound, and sends a notification to your smartphone.
Check in whenever you want
Securely livestream day and night to your Hive app in 1080p HD, or playback videos from the last 24 hours.
Choose what you want to see
You can set Hive View to only detect people, and ignore pets.
Privacy on, camera off
Monitor only when you want, switch on or schedule privacy mode from the Hive app.
Designed to live anywhere
Fits seamlessly into your home. Available in black & brushed copper or white & champagne gold. Designed by industrial designer Yves Béhar.
Cover all angles
Get the best possible view with a choice of wall, shelf or magnetic mount, with a wide 130° field of view.
Grab and go
Want to move your camera to a different room? Just grab Hive View and go. It's light, portable and has over 1-hour built-in battery life.
Set up in minutes
Just plug in your Hive View and set it up in the Hive app via Bluetooth. That's it!
Specs
Camera:
- For indoor use
- 130° wide angle lens
- Powerful dual-core processor
- Detachable magnetic camera cube
- Multiple installation options using the magnetic base and included wall mount kit
- Manual pan and tilt options
- 0-35°C operating temperature
- Rolling 24-hour camera history as standard
Monitoring:
- Motion, person and sound detection
- Adjustable sensitivity settings
Unit Dimensions:
- Width: 88mm
- Height: 137.5mm; 145mm with base plate
- Depth: 88mm
- Weight: 450g; 543g with base plate
Audio:
- Microphone
- Speaker
Power:
- AC power adaptor, Input - 100-240V, 50/60Hz, Output - 5.2VDC, 2.5A
- Removable pins type G (UK), A (US), & C (EU) all included
- 3m USB power cable
- 2100 mAh Li-ion built-in rechargeable battery
Connectivity:
- 2.4GHz and 5.0GHz Wi-Fi (802.11 b/g/n)
- Bluetooth 4.1
Security:
- Encrypted camera footage stored securely online
- Secure web transfer using TLS
- AES-128 encryption
System Requirements:
- Internet connection recommended - 1.5Mbps or higher
- iOS or Android device running an up-to-date operating system
- 802.11b/g/n Wi-Fi wireless router
- Bluetooth 4.1
What's in the box:
- Hive View camera
- Base plate
- Screws
- Wall plugs
- 3m power cable and power supply
Warranty:
- 1 year hardware warranty as standard
  • Peace of mind when you're away
  • Choose what you want to see
  • Grab and go
    Want to move your camera to a different room? Just grab Hive View and go. It's light, portable and has a long battery life.
Hive View - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, built-in microphone
Camera Mount Type
Surface mount, wall mount
8.8 cm x 8.8 cm x 14.5 cm
543 g
White, champagne gold
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Focal Length Control
Fixed focal
Tilting Range (degree)
-45 to +45
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.1
1 - USB power cable - external
Voltage
DC 5.2 V
Motion Detection Technology, Event Notification, Smartphone Monitoring, Audio Detection, video analytics
1-year warranty
Environmental Parameters (operating)
0 °C - 35 °C
Audio Support
Camera Mount Type
Wireless
8.8 cm
8.8 cm
14.5 cm
543 g
United Kingdom
Camera
Colour - Day&Night - fixed - indoor
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
4.88 m
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Fixed focal
Horizontal Field of View (degree)
130
Titling
Range (degree)
-45 to +45
Network Interface
Network Protocols
TLS
Ports
USB
Wall mount kit, screw kit, magnetic base plate
1 x USB power cable - external
AES, TLS, Directive 2014/53/EU
Power Requirements
DC 5.2 V - 2.5 A
Power adapter - external AC 120/230 V (50/60 Hz)
1 Lithium Ion 2100 mAh (up to 1 hour)
Software Included
Hive Video Playback Membership (Trial)
Android, Apple iOS
Limited warranty - 1 year
35 °C
Type: Indoor Camera
Brand: Hive
Price Range Ex VAT: 150 - 300
