Hive Light Dimmable Smart GU10 Bulbs - 10 Pack
Quicklinx: DL32WS00 Mfr#: UK7001584
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT
£107.50 ex VAT
£129.00 inc VAT
Hive Dimmable Spotlights - 10 Pack
Hive smart GU10 spotlights are a great way of making your home cosy when you're there and looking lived in when you're not. Use the Hive app to get the lighting just how you like it, just when you need it, from anywhere.
Get the light just right
If you like your lights up in the kitchen to see what's cooking - and down in the living room for movie night - this is the smart bulb for you.
Control from your smartphone
Adjust these smart spotlights with a tap of the Hive app.
Turn them off together
As well as controlling single bulbs, you can also group sets of our Hive smart bulbs so that they work as one. Perfect for your kitchen spotlights.
Set them up in minutes
Just replace your existing spotlights with ours and pair with your Hive Hub.
Make it look like you’re in when you’re out
Hive Lights are brilliant for giving you a little extra peace of mind while you're away. Make it seem like someone’s home by setting lighting schedules. Or with Mimic mode, included as part of Hive Live membership, get your lights to turn on and off in a varied pattern.
Save energy, save money
Our long-lasting LED smart spotlights are a bright way of saving for the long-term. They're rated A+ for energy efficiency and by controlling them remotely you can make sure they're not left on.
Control them with your voice
All Hive Lights work with both Amazon Alexa and Google Home so anyone can use their voice to turn all the lights on or off together. Perfect for when your hands are full and you can’t get to the Hive app.
Light bulb moments
Did you know you can connect your Hive Lights with other Hive devices in the app so your home works around you? For example, if you have a Hive Sensor your lights can turn on when you walk in the door or off when you leave.
  • Match the lighting to your mood
    Setting the scene with your lighting can really help set the mood. Energize your morning with a crisp cool shade of white then ease into your evening with a warmer tone.
  • Make it look like you're in when you're out
    Hive lights are brilliant for giving you a little extra peace of mind while you're away. Make it seem like someone's home by setting lighting schedules.
  • Save energy, save money
    The long-lasting LED smart spotlights are a bright way of saving for the long term. They're energy efficient and by controlling them remotely you can make sure they're not left on.
Hive Light - LED light bulb with reflector
Light Source Type
Packaged Quantity
10 (specifications are for single item)
Socket Type
GU10
Wattage
4.8 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
350 lumens
Number of LEDs
4
Dimmable
Communications Technology
Zigbee
AC 220 - 240 V
Packaged Quantity
Light Source
Socket Type
GU10
Wattage
4.8 W
A+
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
350 lumens
Number of LEDs
4
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Zigbee
Package
Box
Diameter
50 mm
Length
55 mm
52 g
Type: Light bulb
Compatible With: IFTTT
Brand: Hive
Price Range Ex VAT: 100 - 150
