Product
Hive Light Cool to Warm - Bayonet (B22)
Quicklinx: D2CWWS00 Mfr#: HALIGHTTUNEWB22
20 in stock
£24.17 ex VAT
£29.00 inc VAT
Standard delivery Delivered within 3-5 working days
Hive Active Light - Cool to Warm White - Bayonet fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Hive Active Light - LED light bulb
Light Bulb Type
LED light bulb
Socket Type
B22
Wattage
9 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
AC 220 - 240 V
Light Bulb
LED light bulb
Socket Type
B22
Wattage
9 W
A+
Energy Consumption per 1000h
9 kWh
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible
Power Requirements
AC 220 - 240 V
Package
Box
Diameter
60 mm
Length
120 mm
80 g
