Product
Hive Camera
Hive Camera
Quicklinx: D3HYWS00 Mfr#: UK7001232
Type: Indoor Camera
Compatible With: Alexa, Google Assistant, IFTTT
Hurry, only 3 left in stock!
£108.33 ex VAT
£129.99 inc VAT
Hive Camera
Enjoy the view wherever you are, with Hive Camera keeping an eye on things back home. Packed with great features - live-streamed HD footage, two-way audio and night vision - with the Hive Camera you’ll be set up to see what’s happening, from anywhere.
Includes:
Hive Camera
16GB Micro SD Memory Card
Power Adaptor
User Guide
Screws
24/7 live streaming
Control zoom from your smartphone
Two-way audio.
Livestream in HD.
Record key events
Get a push notification
See in the dark with night vision
Trigger alarm with pre-set sounds: dog barking, police siren, alarm sounds
Talk to your pets. We won’t tell.
Pets jumping on the sofa? Or just missing the sound of your voice. You can talk to them through the Hive Camera and no one needs to know.
Kids home from school early?
Say hello, welcome them home and help them with their homework from anywhere with two-way audio.
Keep an eye on who’s coming and going
Get a clear view from wherever you are, with HD livestreaming, night vision, a wide-angle lens and zoom you can control from anywhere.
See in the dark
Out for the night? Make sure everything’s OK at home with Hive Camera’s night vision setting.
Save your recordings
Includes a 16GB memory card, which you can replace with up to 128GB.
Technical specs:
Dimensions: 97.9mm x 65mm
Weight: 137g
Image Quality: Up to 1080p HD, 30fps, H.264
Lens: 130 degree wide angle lens
Features: Night vision; Speaker; Microphone
Power Supply: AC power adaptor; input 5V, 2A
Memory Slot: SDXC Memory Slot (Max 128GB)
Wi Fi: 802.11b/g/n (Single band)
Operating System: iOS9 or higher, Android OS 4.4 or higher
Hive - network surveillance camera
Network surveillance camera
Camera
Colour - Day&Night
Optical Sensor Type
CMOS
Camera
Colour - Day&Night
Image Sensor
CMOS
Type: Indoor Camera
Compatible With: IFTTT
Brand: Hive
Price Range Ex VAT: 100 - 150
