Hive Light Dimmable - Bayonet (B22)
Quicklinx: D2CTWS00 Mfr#: HALIGHTDIMWWB22
£14.99 ex VAT
£17.98 inc VAT
Hive Light Dimmable - Bayonet fitting
Down for Sunday night, up for Monday morning: set our dimmable smart bulb to the level you want with a tap of the Hive app.
  • Just replace your existing light bulb with a Hive Light and pair with your Hive Hub.
  • Set schedules and pick your brightness to match the moment.
  • Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Make time in the morning
Turn your lights off from your phone after you’ve left for work.
Keep the bogeyman at bay
Little ones afraid of the dark? Connect your Hive Light to a Hive Sensor with Hive actions, so as soon as they’re up, the landing light is too.
Movie nights done right
Lower the lights without leaving your sofa using your Hive app.
  • Save energy, save money
    These long-lasting smart bulbs are energy efficient, and by controlling them remotely you can make sure they're not left on.
  • Get the lighting just right from wherever you are
    Manage your lighting on your phone, so it's just how you like it, just when you need it.
  • Lighting how you like it
    Personalize the lighting for every room and set schedules so your lights turn on and off automatically.
  • Turn them off together
    Group your Hive Lights so that you can control all of them together.
Hive Active Light - LED light bulb - B22 - 9 W - warm white light - 2700 K
Light Source Type
LED light bulb
Socket Type
B22
Wattage
9 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Beam Angle
240 degree(s)
Dimmable
Light Source
LED light bulb
Socket Type
B22
Wattage
9 W
A+
Energy Consumption per 1000h
9 kWh
Warm white light
Colour Temperature
2700 K
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible
Package
Box
Diameter
60 mm
Length
120 mm
80 g
71 mm x 71 mm x 136 mm / 129 g
